Caporegime
- 18 Oct 2002
AMD/Nv can't lock anyone to anything regarding VRR over HDMI 2.1, you either support HDMI 2.1 or not???
VRR over 2.1 is optional apparently. Plenty of wiggle room there!
I mean in context with AMD/Nv can't lock you into their own AS implementation if Samsung/LG/whoever states 2.1 VRR support laid out in their specifications- it would have to work on any gpu with 2.1 VRR support.VRR over 2.1 is optional apparently. Plenty of wiggle room there!
Bottom line imo it's insane the confusion regarding AS compatability and we know what it is.
Not quite sure what you are saying there - nothing stopping AMD or nVidia using propitiatory extensions with HDMI 2.1 and not supporting VRR while working with another company to produce a custom adaptive sync implementation for their device - but if they want to support 3rd party devices that are made to the HDMI 2.1 spec as per the standard with VRR then their GPUs would have to support the full specification. VRR is optional to the spec due to the vast range of devices that will use it - portable devices, DVD players, etc. are unlikely to ever implement or potentially even need to implement all the features of HDMI 2.1.
Why are you making it so complicated? What he is stating is pretty simple.
If a TV has VRR support over HDMI 2.1 than any GPU that supports VRR over HDMI 2.1 will be able to connect to it and use that feature.
I'm sure if nVidia can they certainly will![]()
I reckon they'll give it a good go!!
Hope not
The writing was on the wall when new & improved Gsync came with a propeller that made your monitor sound like a fan oven.
You are wrong. The module itself, an Intel Altera Arria 10 GX 480 required active cooling. Nothing to do with the screen.that has nothing to do with Gsync lol.
those crappy lcd screens need fans or they overheat - the thickness of the monitor and its heat is not from Gsync it's because they wanted local dimming and HDR and they needed to get several times brighter than previous gaming monitors.
One of the big reasons TVs are always ahead of monitors with technology is its often easier to implement new tech in a bigger device than trying to shrink it into a tiny monitor.
and if anyone wants to know why their latest smart phone can get super bright HDR without overheating - because they're all OLED screens not crappy LCD - OLED is the future, just try asking ASUS how well their BFG screens are selling LMAO
Correct, so far Nvidia supports this while AMD does not.
The tricky parts comes from pass-through - now put a AV reciever in the mix, will it take HDR, VRR, 4k, 120hz and send it to the TV?
