How so? Maybe you can be clearer in what your asking? You said it 'needs to be' then 'failing that'. I assume you were asking if it was a fast charger? You were simply asking if it would work then? I honestly don't get it. I was trying to help, saying it won't say 'fast wireless, charging' look -
No. You were, as usual trying to be clever and arrogant. I just asked if anyone was using a wireless charger, and if so what one. Its quite simple.
You said about it only being 10W and I replied that it needs to be 11W and as per the links support EPP to fast charge Pixel devices. I then said...
I'm just wondering what others might be using, failing that I'm just going to order one I like the look of! TBH it will be for either my desk at work or the bedside table, neither of which need to be particularly fast.
*Please note the 'need' in italics in my original post and also the bold as you seem to have missed that the first time round.
Tell me, seriously, you see that as argumentative and arrogant over trying to be helpful?! Maybe you have the issue, not me.
Lol. OK, yeah I'm the one that's the problem, sure. Except that also wasn't the post I was replying to was it. I was quite obviously replying to your post that was directly above mine.
So you said 'it needs to be a fast charger' then later you basically said 'it doesn't matter if it's not a fast charger'. So what are you actually asking us about the one you linked? Will it work? Yes, it should charge your phone.
I said it needs to be 11W to charge Pixels fast, the nI provided two links as reference, I then said that I don't care if the one I get isn't fast charge as it will just be for overnight or during the day at work. What part of that is it you do not understand?
Re read the thread from post 1455.
@_Jimlad_ seems to have followed it OK.
