Root filesystem has become read-only
15 Feb 2003
Europe
My Raspberry Pi sd card recently became full causing a system crash. Since then it has been read-only. I gathered that the sd card was now at the end of its life, so did a 'dd' image of it and put the image on a new card.
When the Pi boots (Raspbian Buster), it seems even with the new card the root filesystem is mounted as read-only.
There is nothing wrong with the sd card, I can mount it in another system and it has full read-write capabilities, so the problem seems to lie with the image. I have ran an fsck and didn't find any errors, and manually remounting it will restore write privileges, but I need it working at boot.
sudo mount -o remount, rw /
Any suggestions on how to fix this?
6 Mar 2008
Stoke area
It's odd as I have an SD card that works in my D810 but I can't format/edit anything on it in Windows or Linux. Camera can't format it it either but can still write to it.
Can you set write privileges then make a backup of the system, then try writing that to an SD card?
