- 14 Aug 2018
When the OP asked about Single Threaded performance why would you post a graph that refers to IPC? The two are not the same!Very well, so well that AMD tops the charts.
https://www.guru3d.com/articles_pages/amd_ryzen_7_3700x_ryzen_9_3900x_review,9.html
This is the graph you should have posted...
As you can see Intel are still slightly ahead in Single Threaded performance and this is at stock. Considering the Intel CPU's will overclock relatively much higher than Ryzen then the single threaded gap will only get bigger.
There simply is no justification for showing an IPC chart when somebody asked about Single Threaded performance, especially when the Single Threaded performance graph is on the same page as the IPC one.
