I always have turbo boost disabled and set my clockspeeds manually, because I have the cpu to lower clockspeeds when idel anyway, so I dont see the point with turbo boost.
Depends what you can achieve manually versus boost behaviour, etc.
The huge gap between 9900K and 9900KS in SINGLE threaded tasks is weird. The main difference between these CPUs are clocks in MULTI threaded mode, while single thread clocks should be equal for both.
You get very few situations where you are truly single core boosting though - so the ratios of multi-core clocks will probably have an impact along with potentially factors like maybe the KS is boosting very highly for a short time but in doing so hits the limits so hard that it actually drops below the K briefly over a longer period before coming back up again to level out eventually (or some variant of that kind of behaviour I've not actually looked into it).
