 - 21 Sep 2018
Please see my earlier posts for context.
I've seen a 3900X score higher than that at stock in Cine20.
I have, I did, and now I'm seeking clarification. 9700K's 800MHz advantage - at the expense of Christ knows how much power - saves you 2 seconds on an image export. Is that a good thing or a bad thing?Please see my earlier posts for context.
Is this the only area intel fans are grasping at? Officially an one trick pony.
Look my post above, my 3900X has even PBO forcibly set to OFF and just the settings needed for 1usmus powerplan to work.
Which for the X570 Taichi are found here
https://forums.overclockers.co.uk/posts/33133217/
Ah right, Nice one. I went for the 1Usmus powerplan tehn didnt bother as like you some of the settings were not available (I'm on Phantom gaming 4) So I will try the settings same in my BIOS for my 3800X. I know the powerplan is predominantly for 3900X but worth a try. So just to clarify - you see better performance on the 1usmus powerplan?
This same CPU scored 528 in a different motherboard which would only boost to 4575Mhz but in this one that normally boosts to 4625Mhz it scored sightly less, which was not what I expected. On the plus side this motherboard scores 200 points higher in multicore at stock, which is higher than most I've seen. As this is mainly used for multicore work I'm happy with that.I've seen a 3900X score higher than that at stock in Cine20.
	When I was assessing which system I wanted to use for my photo editing, I just wanted to get the fastest one, be that just 10% faster, it didn't really matter, I just wanted to get the fastest for my usage within reason.I have, I did, and now I'm seeking clarification. 9700K's 800MHz advantage - at the expense of Christ knows how much power - saves you 2 seconds on an image export. Is that a good thing or a bad thing?
My 3900X runs slightly warmer than my overclocked 9700K when I tested them with the same cooler.Pretty bad considering the power and temps. In addition to the 3900X has 12 cores / 24 threads running cooler and more economically![]()
FYI der8auer on today's review about 3960X had CB20 run, including 9900KS, 9900KS @ 5.2 and 9900K.
Which shows that clocks mean nothing today when out of the box 3900X as fast in single thread at the 9900KS and the 9900K.
And takes overclocking 9900KS to 5.2Ghz to get ahead, but that requires serious cooling that no AIO let alone (air) heatsink can provide.
from this video...
Whay are his CB scores so low? You'd think he'd be able to chalk up a bit more being an experienced overclocker.
Yes, his 3900x single thread is a little low though in my B450 Tomahawk I used to score 483 so I'm not sure what motherboard he's using. His multi threaded score is around normal for stock but using the 1usmus power plan that you kindly posted up then that's where I saw the biggest improvement in multithreaded.Yep, his speeds are pretty low and doesn't need to overclock the Ryzen. Just use proper powerplan but well.
His 9900k 5.2Ghz overclock seems very low at 513 as I would have expected it to be around the same as my 9700K (542+) @5.2Ghz. Maybe mine is a Russian 9700K.![]()
The highest ST R20 Ryzen score is 547, this is at 4.7Ghz, the highest Coffeelake score is 580, this is at 5.45Ghz, a score difference of 6% with a clock speed difference of 16%, so yes if you can get past the IPC difference between Zen 2 and Coffeelake then you can beat Zen 2 score, but that IPC difference is very obviously there, if you cannot see that you don't know what IPC is.
On your Lightroom result. I don't use it so i have to concede that to you, i do think its strange that you don't show the filters used for the 9700K.
However, i can use google and the first review i came across has Zen 2 winning.
https://www.pugetsystems.com/labs/a...adripper-2-Intel-9th-Gen-Intel-X-series-1592/
Unforunately where it concerns Photo editing you do not have an inkling of what you are talking about. This is the best thing you have said on the subject...Actually doing the work, rendering the image Zen 2 is clearly faster. but he can save 2 seconds exporting that work which is entirely dependent on IO throughput, IE the speed of his hard drive, his memory...
So he can shave minutes off his workflow with a Zen 2 CPU but for some strange reason has gone Intel and is now not only trying to justify it but still trying to say Intel is faster pinning that entire argument on exporting the work, this is how ridiculous the Intel vs AMD argument has now got.
My 3600 does a better job in Lightroom than his 9700K.
On your Lightroom result. I don't use it so i have to concede that to you....
If this doesn't encapsulate how nonsensical your comprehension is then nothing will.My 3600 does a better job in Lightroom than his 9700K....!
If you really think that your 3600 is faster than my 9700k in photo editing please, please, PLEASE download the free trial of DXOPhotolab and I'll send you my preset and you can then run it on the same photo and we'll see what it scores. Come on, put your money where your mouth is.
That would be great to see. I'll just upload them now. The same goes for anyone else as it would good empirical data for me to have.I'm interested to see how mine compares against a 9700k - plse send me the details - already have DXO installed.
All it appears you can do is post up Puget charts which have no bearing whatsoever to my workflow and then start talking about unrelated things like 'render' and the speed of memory and hard drive. This demonstrates how you've seem to have totally lost the plot.
Just for reference the systems are using the exact same SSD and the the 9700k was using memory at a lowly 2666Mhz!
- I've written repeatedly I'm not using Lightroom in this test, I'm using DXO Photolab!
You admitted you have no clue as to how DXO Photolab or Lightroom works apart from what you can see on charts but instead of asking for clarification you attempt to break the point down to your own pro Ryzen narrative. Spewing out charts in some pseudo defence of something that is not even related to my point.
