- 20 Oct 2010
Was 82 i think
Bit of a lame attempt on my 3970X - only boosting to 4.05GHz with my AIO barely keeping up:
Imagine what score he will get if he can get a decent overclock?Juzuss ####'### hell!
I'll update later....
My first pc was also AMD, can't remember the exact model but an athlon , anyway I remember I had problems with bsod so I decided to take everything apart and put back together ( note I never built or had any idea how to ) basically I pulled out the cpu without opening the socket and put it back and bent a lot of pins and broke 2Imagine what score he will get if he can get a decent overclock?
AMD killing it. Which is very nice to see as my first cpu was an AMD one and I was AMD only until core2duo came about.
Lol. I never damaged any cpu or gpu but I did **** up a psu which went bang due to over tightening the mobo and bending it. I learned my lesson once PC World charged us £100 to tell us the reason another pc I had issues with was not working properly. That was about 20 years ago.My first pc was also AMD, can't remember the exact model but an athlon , anyway I remember I had problems with bsod so I decided to take everything apart and put back together ( note I never built or had any idea how to ) basically I pulled out the cpu without opening the socket and put it back and bent a lot of pins and broke 2, I got it repaired and it worked some 2 more years and then it died
Not sure why CPU-Z shows it as a budget 9980XE but its a 10980XE @ 5Ghz
11660
Bruh lolThat's because they are the same chip
Aww, what a cute little score![]()
@humbug any chance you can update my scores please?
You messed up the ST scoreboard again. Time for Kaapstad to take over me thinks...All updated.
Congratz to g0th2000 for breaking the 17.5K Honorable Mentions score with 17824 points. You now top that spoiler![]()
He knows I am only kidding^
That's not nicebe gentle with our Humbug
I know![]()
