Caporegime
- 9 Nov 2009
- Planet Earth
Actually yes you're right. I remember doing that on my Xeon 24 core system, though to get the cores to load up I had to select at least 6 simultaneously. The problem was that quite a few would error and then it became a chore to go and find which ones and then redo them, which in turn would offset the export into Lightroom which just meant more work for me in the end.
I'll try the batch export again for v3 which has recently come out to see if it's any better as then the 3900X will come into it's own and that gives me another option.
Well I know the version last year didn't have that problem but I was only running two at the same time,in batches of 50 pictures.
Some of my machines below.
The reality is that my 9700k is ~37% faster. Compared to your Geekbench 3 my 9700K is ~25% faster.
