Caporegime
 - 8 Jul 2003
 - In a house
Turn off HT, and now run em at stock!
You can bet your ass that they are sitting there questioning that bounty programme about now.
Paying people 10s of thousands of dollars to make their CPUs look bad heh. They've double down on it expanding the program though since some of these vulnerabilities started to come to light.
You forgot to add the signing of an NDA for those people to able to collect those 10's of thousands of dollars.............................................in any other form of business it would be called bribery, and in any financial institution it would be called corruption.
LMAO
I no longer have to try and justify an Intel cpu to myself and I'm glad I'll no longer have to wonder about what security issue that ruins performance will show up next.
A security patch that destroys the CPu's overclocking potential also means Intel just lost a whole lot of gaming performance.
My 3950x is only a few days away now
Widely reported 3 days before this video was posted:Update incoming, stops overclocking.
So it is sounding like software voltage adjustment will be disabled when SGX is enabled. But voltage will still be adjustable in BIOS. SGX is required for playback of 4K UHD Blu-Ray, but little else on home PCs.Intel is “working with system manufacturers to provide a balance between performance and security for platforms that support overclocking of unlocked processors,” an Intel representative said in an email. On processors—such as Intel’s K-series chips—the preference may be set to allow voltages to be modified.
“We expect limited overlap between use cases where Intel SGX and overclocking are both relevant,” the representative added, however, probably meaning that there’s little chance that the average PC user will be affected. In the case that the mitigation is applied, however, Intel’s XTU tuning utility will not allow voltage changes from the default.
Yeah, 4K UHD playback is completely messed up on PC. You need an expensive official drive (with an AACS 2 chip), an Intel CPU with SGX and use the iGPU (not a discreet GPU). You also need the software which costs about the same as a dedicated player. Needless to say, AMD isn't supported at all. It is DRM gone mad.Wasn't aware it was required for that - I pretty much stream or use a dedicated device for 4K/UHD blu-ray these days.
Well I do. Still useful for converting physical into digital. Streaming is convenient but can't match the quality of physical (especially for 4K). Then you have issues like Ultraviolet/Flixster closing down.I don't know anyone who still has a disc drive in their PC. I suspect Blu-Ray discs will wonder off into oblivion sooner rather than later anyway
Intel vulnerabilities still a raging fire I see, I was going to donate my old 6700K to a family member but it may just be taken out back and shot.
WUT?![]()
Long story.
 It's never ever stopped you from explaining anything before..............................................go ahead
