How often do you lot have your eyebrows done?
I have them tidied up every 2-3 months no styling or shaping as such just keep them neat usually just comb placed over the top and 1-2 passes of razor and remove the odd hair that might be starting to grow between and that is it.
I trim occasionally, I'm getting on a bit. You lot will be saying you don't do your backs next.
I was getting my hair cut last month and nearing the end the barber just whizzed over both brows with the clippers. First time it's happened so at first I thought I'd walk out there with no brows!! Must have looked at them and thought, **** me those need to come down a bit. Meh, not against it, just hadn't thought of it myself. If I had done it, I'd actually end up taking them all off by mistake.
If I don’t trim my eyebrows every couple of weeks I end up looking like a mad professor, nose is pretty bad as well.
You younger guys, just wait till you hit your mid 30s :p
When I get my haircut the Turkish barber does my eyebrows and ears.
Same with mine which is usually about once a month he trims my eyebrows down.
Thankfully my ears aren’t hairy like some guys I’ve seen lol. I do get the odd one coming out but usually I just pluck it out with my missus tweezer or I get her to do it. She finds it oddly satisfying:p
I try to get mine done every 2 months. I've been a bit slack lately, and Mrs Evangelion has been giving me 'the look', so it's probably time for another threading session with Jusef.
