No word if it fixes the brightness bug in windows with these hotfixes so probably will be skipping these till it is fixed. Had to revert back to early December i think it was drivers.
@LtMatt
My only annoyance with these drivers is we cannot have the FPS cap without using Chill and Antilag together because these are mutually exclusive.
Please bring back the limiter.
The fps limiter is still there it's just part of chill to use it set the min and max to what frame rate you want to cap at.
To use chill set the min fps different from the max.
Antilag can be used without either or together.
Edit
Chill is a better method than the old frame limiter. It delivers frames faster when ready.
The best way is to max frame rate say 144 and set min to 142 etc or for 60hz max 60 and min 58
Kinda glad i switched to the green team (something i NEVER wanted to do) after about 10 years of AMD. All these driver issues is something that we really dont need to be putting up with, that new 2020 driver was the last straw for me.
Bought a 1660 Super (MSI Gaming X @ £249) and DayZ is running waaaay better and hardly stutters at all now. I'm not getting video freezing when watching multiple streams/youtube at the same time while using hardware acceleration in Chrome. Those clock speeds dropping really low are a thing of the past, the 1660S stays pretty much between its normal and boost clocks (even when locked at 60fps) while using max performance option in the drivers. The 5700XT i briefly had was dropping down to as low as 59Mhz in GTA V. My Vega 56 only ran around 1400Mhz but at least locking a State was possible with the older drivers to get it over 1500Mhz.
I'll keep my eye on what upcoming GPU's AMD have in the pipeline but for now this 'best 1080p card' will have to do me until AMD can bring something to get me back.
As a bonus, Freesync is working with this card
Btw my 3900X is running sweet so i still have something AMD in my case![]()
Remember when AMD used to release 'hotfixes', to fix their broken drivers, well Nvidia are releasing them now too.![]()
Locking Pstate is still possible with 2020 drivers.
I tried DayZ for you couple months and it was fine on my system so not sure why you have had this issue tbh
Also I always have multiple tabs on my second monitor from watching football, YouTube, twitch and mixer not all at once haaa
Again no issues with my GPUs clocks
Anyway the most important thing here is you getting what you want from your system.
What driver issues?
Dont try to justify the £250 1660S instead of a RX5700 by saying "driver issues blah blah"![]()
Well i upgraded every single component and still had stuttering, even bought a mains conditioner and that didnt fix it, hate to say it but its Nvidia that has fixed it. I wish this wasnt the case but it is what it is and now i can play DayZ again after more than 3 years of stutter.
I also play Second Life and the OpenGL from Nvidia is at least 50% faster than my Vega 56 in performance.
Pains me to say this but, it just works lol
Yeah OpenGL nvidia owns I totally agree, the best thing here for AMD is Vulkan API they is a good few OpenGL titles/emulators jumping from OpenGL to Vulkan.
Cannot use Antilag & Chill, but we could use Antilag and the FPS limiter. When you activate one of them the other gets de-activated.
This happens to me too, except in overwatch where I noticed after pressing alt-z that they are both enabled and I get both sets of beeps (AFAIK) at the start upon launching![]()
Yep. Fps limiter was great, Chill is not and never was good.
Fixed Issues
Known Issues
- Game and boost clocks may be incorrectly reported for Radeon™ RX 5500 XT graphics products in Radeon Software.
 - Radeon Software Install may experience an error and fail to detect AMD graphics hardware when a certain WiFi adapter is enabled in the system.
 - Rocket League™ may crash or experience an application hang after performing a task switch.
 - A black screen may occur when Performance Metrics Overlay is open and changing game resolution.
 - After disabling Radeon Software Overlay users may still see the toast messages for the overlay shortcut while in fullscreen games.
 - Audio from custom scenes may continue to play after recording or streaming has been stopped.
 - Installer audio has been reduced as it was too loud on some system configurations.
 - Some users may be unable to select drop downs in graphics settings for Tessellation Mode.
 - Radeon ReLive may appear to be missing or not available to install on some system configurations with Hyper-V enabled.
 - Newly added game profiles may fail to enable the currently selected global graphics settings options in their profile.
 - Performing an auto update from web to Adrenalin 2020 Edition from Adrenalin 2019 Edition may fail with an error code.
 - Improved Radeon Chill experience when using a gaming mouse.
 - Switching between borderless and fullscreen in some games when Performance Overlay is enabled and Radeon FreeSync is enabled may cause stuttering.
 - MechWarrior 5: Mercenaries™ may experience black corruption near the bottom of the screen close to the player model.
 - Radeon Anti-Lag may fail to enable for DirectX® 9 applications when enabled in the global graphics settings options.
 - Radeon Anti-Lag may fail to enable for Counter-Strike: Global Offensive™.
 - The custom stream option may fail to present users with a url box to choose their endpoint.
 - DirectML Media Filters may fail to apply Upscale and Denoise when attempting to do both at the same time on one image.
 - Some Radeon FreeSync enabled displays may experience LFC intermittently enabling mid game causing poor performance or stutter.
 - A grey box may prevent users from setting custom hotkeys in the scene editor.
 - Performing Auto Tuning for graphics clocks on Radeon RX 5700 XT may result in an extremely high OC or unstable OC.
 - Some games may experience instability and screen loss or control loss when performing a task switch when the Gaming profile is set in Radeon Software which enables Radeon Enhanced Sync.
 - Radeon Image Sharpening may fail to enable in Star Wars Jedi: Fallen Order™.
 - HDCP 2.2 enabled content may fail to play on some Radeon RX 500 series graphics products.
- Some Radeon R9 200, Radeon R9 300 and Radeon R9 Fury series graphics products may experience instability with a limited number of DirectX®9 or DirectX®11 games when using a high refresh rate 120hz+ display. A workaround if you are experiencing this issue is to lower your displays refresh rate.
 - Trials Rising™ may experience excessive fog/smoke in some areas of the game.
 - CPU usage may remain sometimes remain high once Radeon Game Advisor has been invoked during a game.
 - Factory Reset install may keep previously configured Radeon Software game profiles. This can cause mismatch between global graphics settings and per profile settings.
 - Text overflow in some UI boxes or toast messages may be experienced in some language localizations.
 - Controls for vertical sync may be hidden or disappear when Radeon Enhanced Sync is enabled.
 - Radeon Software may open with an inconsistent size or may not keep it’s previously set size when opened.
 - Some Vulkan® gaming applications may crash when performing a task switch with Radeon Image Sharpening enabled.
 - Integer Scaling may cause some video content to show flicker when the display resolution is set to less than native resolution.
 - Performance Metrics Overlay may appear to lock frame rate at 60 fps when performing a task switch in or out of a game.
 - Battlefield™ V may experience an application hang when changing settings in game with Radeon Boost enabled on Radeon RX 5700 series graphics products.
 - Performing a resolution change while Radeon Software overlay is open may cause an application hang or TDR.
 - Enabling Radeon Image Sharpening on HDR enabled displays may cause colors to become washed out.
 - Mortal Kombat 11™ may experience an application crash after the splash screen on Radeon RX 5700 series graphics products.
 - SETI@Home may be provided incorrect results from Radeon RX 5700 series graphics products.
