Caporegime
- 8 Jan 2004
- Rutland
Advanced\AMD CBS\NBIO Common Options\XFR Enhancement\Accepted
Set Precision Boost Override Manual
PPT Limit 999
TDC Limit 999
EDC Limit 999
Overdrive Scalar - Manual
customized - 5x
However make sure the actual PBO is OFF that's under
Advanced\AMD Overclocking\Accept\Precision Boost Overdrive
Set Precision Boost Overdrive - Disabled
Wording might seem weird, especially why we are turning on boost under the XFR settings but disabling it on the actual PBO settings. But works like a charm with the 1usmus powerplan
And that because I am trying to push the system to it's limits because X4 is hammering hard 2 cores (constant 100% load) and lightly 4-8 cores (60-80% load) depending the area we are in.
eg quiet areas is pretty low, on battlefield areas where there are dozens of ships per side it cranks the core usage up.
So with the above settings I get a 4600 & 4650 2 core 100% hammering for hours, while the rest are boosting as they go. Which is the point of gaming settings, as the system considers them light threaded applications.
Awesome, appreciate it!
