How hard is it to develop an app?
Caporegime
24 Oct 2012
Yer nan's knickers
For someone like me, whose experience in this field stops at QBasic and Turbo Pascal 7, with some web experience. I need an app that can pull data from a database, allow data to be put in to the database, upload images to the database and generate easily searchable records.
Is this achievable? Loads of internet results of "learn to make apps in 5 minutes" and all that but we all know how marketing works.
I have the perfect toolkit for you. Basic for Android or B4A. It's about as simple as you can get, BASIC language similar to VB6, and drag and drop interface. Ever expanding library of plugins/user controls or easy to write your own. Works with iOS also it's actually called b4x now I think.
https://www.b4x.com/b4a.html
Use mysql lite as database, plenty of code on B4A forums, you need to subscribe if you want to post however.
Cheers jsmoke! I'm still trying to make sense of it all, seems that an app for Android is very different to an app on iOS and the biggest thing I'll need is accessibility for anyone.
They have a version for iOS also, I think you can port the UI stuff.
If you want to write a cross-platform app with no experience your best bet is probably Xamarin which is free and something like SQLite for the database.
Basic is a dead language, you're much better learning C# (for Xamarin) or Java (native Android) and Swift (native iOS). The best option is two native apps but then you have two languages / tools to learn.
You also have to bear in mind there are thousands of tutorials and tutorial videos using native languages or frameworks like Xamarin; if you get stuck you'll find it far easier to get help.
Here's a database tutorial using Xamarin for example.
I was going to suggest Xamarin after doing a little bit of research on it myself, seems like a fairly simple way to target the main mobile platforms. But yeah, you'll need to get acquainted with C# to do so, it's not the most difficult language though and as stated there's a lot of resources to help you along the way!
There's nothing wrong with basic it's just used as a layer and is converted into java before compiled. It does everything you need it too.
As a current VB6 developer at work I'm very interested in this - will certainly take a look
It's a very verbose and ugly language, if it gets the job done though fair enough. I'd personally bite the bullet and learn C#/Java though and make use of the tonnes of open-source libraries that make your life easier.
An electronics engineer colleague of mine uses Swordfish to write firmware for PIC microprocessors using BASIC in a similar way and he's happy enough. Unfortunately it doesn't support some of the more powerful chips we might need to start using so he might have to go back to using C instead and rewrite all his code but that's not a fault of the language.
If you understand OO, then C# is a doddle to pick up with a modern IDE. I've never 'learnt' C# but I have thrown together some applications with it when I've needed some tools etc....should be very little friction for an experienced programmer.
Thanks for the replies all. As you'll probably have gathered from around the forums I'm busy concocting an idea and getting ready to launch a business, so any and all advice is very much appreciated.
Flutter might be of interest to you. It's a framework by Google using Dart and, similar to Xamarin, allows you to develop for ios and android with a single codebase. I'm a C# dev by trade and having played with both Flutter and Xamarin I prefer Flutter even without prior knowledge of Dart.
If you've already got web experience, just make a website for it.
Presumably if you're going to be connecting to a database it'll need a network connection for the app to work anyway so having no connection wont be an issue? Unless you meant a local database on the device itself?
It'd be more limited in terms of access to the device hardware, storage, etc but from your description it doesn't sound like that'll be an issue. You won't need to worry about porting code to different operating systems, etc.
I'm a front-end dev and dabbled with Flutter when it was still fresh and managed to get a relatively simple app working easily enough. The main benefit was the documentation, it was good from the beginning and I can only imagine it's much much better now more and more people are using it. Plus it's Googles own project so it's an evolving framework and compiles to native Android and iOS.
