- 23 Mar 2011
I recently put together a build with this board.
The other day I noticed the internet would disconnect, then instantly reconnect for no reason.
Not sure if this is the culprit, but when installing the IO shield it was a bit of a pain to line up etc. Anyway I assumed it was sorted but once I had complete the build, I noticed a tab was inside the Lan port. Same as this picture (picture isnt my own)
I assumed this wasnt an issue as it was connecting etc... but I'm now guessing this is wrong and could it be the cause? If it is I'd assume it wouldnt connect at all which is odd
