 - 7 Aug 2004
Hi all, so I have an unusual internet setup. My house has an Asus RT-AC87U connected to a BT fibre modem which works great & as expected, getting 68mb down, 18 up always without fail.
In my office which is in another building, I have my Asus RT-AX92U which sees my 87U as its ‘WAN server’ - it is connected via a 1gb lan cable.
The issue is, my 92u connects fine at full speed for several minutes then for no reason I am aware its connection speed to the net drops to 2mb down 1 up…..(or slower)
The only way to stop this is reset both routers, which again works fine for some minutes then speeds drop again.
Settings:
I want my office and the house devices on there own separate networks.
Any ideas why this frustrating slow down happens?
Settings:
Asus RT-AC87U - default settings- manually assigned IP address of the 92u is 192.168.1.5
87u’s DHCP router setup is 192.168.1.2 - 192.168.1.254
Subnet 255.255.255.0
Asus RT-AX92U - WAN is auto IP (I have tried the 87u’s ip manually of 192.168.1.1 / 255.255.255.0 - both this and auto ip works fine and connects albeit with the above issue, so the data is going through)
92U’s DHCP address range is then 192.168.50.2 - 192.168.50.254
In theory this should work ?? The 92U see’s its wan port for data at 192.168.1.1 then moves this to its own DHCP 192.168.50.2…etc
 the room the LAN goes into is the spare room NEXT to the office room - its not suitable to run a cable through the wall at the moment so it goes into a 1GB Power lan plug, and travels 15 feet to next rooms power plug and shock horror, works, well, it did until slow down, I reset the plug and now its fine 2 days later, no idea why.
