- 7 Aug 2004
Hi all, so I have an unusual internet setup. My house has an Asus RT-AC87U connected to a BT fibre modem which works great & as expected, getting 68mb down, 18 up always without fail.
In my office which is in another building, I have my Asus RT-AX92U which sees my 87U as its ‘WAN server’ - it is connected via a 1gb lan cable.
The issue is, my 92u connects fine at full speed for several minutes then for no reason I am aware its connection speed to the net drops to 2mb down 1 up…..(or slower)
The only way to stop this is reset both routers, which again works fine for some minutes then speeds drop again.
Settings:
I want my office and the house devices on there own separate networks.
Any ideas why this frustrating slow down happens?
Settings:
Asus RT-AC87U - default settings- manually assigned IP address of the 92u is 192.168.1.5
87u’s DHCP router setup is 192.168.1.2 - 192.168.1.254
Subnet 255.255.255.0
Asus RT-AX92U - WAN is auto IP (I have tried the 87u’s ip manually of 192.168.1.1 / 255.255.255.0 - both this and auto ip works fine and connects albeit with the above issue, so the data is going through)
92U’s DHCP address range is then 192.168.50.2 - 192.168.50.254
In theory this should work ?? The 92U see’s its wan port for data at 192.168.1.1 then moves this to its own DHCP 192.168.50.2…etc
