I think if you are going for a battery on straight out financial terms, its borderline even with shopping around for the best deal to get a break even in 10 years. Infact I'd say its highly unlikely.
The cheapest way to do it even now seems to be with a sofar me3000sp and pylontech batteries.
But if you go for 6kwh useable (7.2kwh) and use it fully every day, assuming a 13p/kwh charge then you can save 6x365x0.13 =£285 a year.
A quick glance at Ebay says that system will cost you £3k and that's Installing yourself , so over the 10 years it will cost you £150.
You could argue the batteries working that way will last 20 years, and so you could almost double your investment over the 20 years.
However, that's quite flawed, you dont generally get enough solar to charge the batteries in the winter.
My sofar which has been in for just shy of 11 months has done only 183 full battery cycles not the 330 odds you would expect if it had been cycling every day for 11 months.
Theres a caveat in there about micro cycles where it discharges a couple of kwh and then is recharged up to 100% again.
My system doesnt read that so I dont know how much of that the system is doing, i can only read total full cycles of the controlling battery, some days its doing a lot of micro cycles, and some days none at all.
So you can set it to charge on e7. And so save 8p /kwh, but say you do that for the 150 darkest days of winter, you are only saving 6x150x0.08= £72
Plus the 183 days I've saved is 183x6x0.13 = £142 so a saving of £214
So after nearly a year of running batteries I cant see the breakeven being ten years, 15 or so seems logical I think.
So with all this said, I would obviously advise against batteries right?
On the contrary, I'd say if you are going batteries. go big.
I'm about to invest another few thousand to get my storage to around 22kwh, as that's what my house tends to use on an average day.
The new lux parallel systems will run the pylontech at 90% discharge in comparison with 80% discharge on the sofar.
And being parallel, they can cover 7.2kw of load, instead of the 3kw of the sofar.
Will it break even in 10 years? Not a chance, but it will give me a ton of satisfaction at not buying leccy at 13p pretty much ever.
This month isn't necessarily a great month to use, but I'm gonna anyway, this month I've exported over 200kwh, but bought 175kwh.
Theres no other way to justify my expenditure than just to say this sort of thing irritates me.
I mean at 13p, the total cost is only £22 odds, so hardly earth shattering, but it just irritates me.
Most of my solar is not fit, so I'm not getting paid for most of it, and so I want to self consume as much as possible.
My analysis is probably similar to many on here, and I know Mmmmikey has decided that he is going to use the export tariff to offset cost and charge overnight, and make the sun powered immersion redundant by also immersing overnight too, but I'm looking to self use, rather than *profit*, so I'm looking to move to using more of my solar rather than exporting it.
Or at least, that's my feeling today, I've flip flopped on this quite a few times, including recently calling ovo about the v2g trial.... mostly because I'm interested in using the v2g charger as a v2h charger after the trial, but also because they were advertising a high export tariff in the evenings for grid support.
However my leaf is a 15 plate and still under warranty. You can sign a letter to say you opt out of the warranty... but it's not just the battery warranty, it's the entire car warranty.
Also they are not really interested in large solar arrays, they ideally want to be at the 4kw array size.
Finally they want around 1000 people on the trial, so far they have less than 100, so goal posts may move.
Hope that helps someone
