- 3 Oct 2009
- Wales
Did it on my full suss. Front wheel worked perfectly first time. Rear wheel took 2 attempts and still isn't right as it is sometimes flat when I go into the garage if it's been a week between rides.
The main reason I did it was because I found it so difficult to get the tyres off the tubeless compatible wheels that I was genuinely worried about getting stuck in the middle of nowhere with a punctured tube unable to get the wheel off to put in a replacement! (dodgy thumb so I can't apply full pressure with my left but I've been on group rides where its taken a team effort to get it off before) Obviously the risk is still there if I slash a tyre but hopefully less likely.
I haven't bothered with the hardtail as its running slime tubes and has done 4 figure mileage without any punctures
