I have said AOC monitor with a 5700XT. What issue you having?
Well with my vega 56 pulse, when i tried the new 2020 drivers after reboot the screen was almost dark at the windows loading screen with the animation i think ppl online said it was the contrast but i dunno it was just like really dark. Tried to install the next set of 2020 drivers i think and same issue so gave up on the new ones. Others are reporting issues similar on amds own forums i think i read.
They say you can turn the monitor off then back on and it fixes it, i never tried and nor want to as id be forced to do it each time i booted.
Went back to 19.10 driver which seems ok for now. I can wait its not like its magically gona make games quicker or something lol.
Id like to say i used ddu for it but i cant recall now. I know i did use that or amd clean up not long ago cos i lost all my saved profiles for underclocking grr.
Plus the new drivers are missing freesync range when you hover over something in display tab from old drivers, its not in new ones afaik. Nice to use when u use that cuc thing to change freesync ranges to check if it worked or not.
