- 26 May 2018
- Bewdley, UK
Wahoo Still no Haribo?
Unless they're in the box... no![]()
also sweeties? haha
Update:... There were no Haribo
I’ve got pics, but I’m not near the computer and I’m having a mare working out how to get them hosted properly from a mobile...
I’ve barely sat on it, so can’t comment on comfort, but quality wise it’s absolutely top notch...
That looks a good way of applying the thermal paste. Also that cooler is huge.So...
Contraversial, I know, but I went with the 'use a gloved finger to spread the kryonaut' method on the CPU...
Then I remembered that no matter which way I'd done it, someone would tell me I'm an idiot and i shoud have done an 'X', or a pea sized blob, or that you should sling loads on, or as little as possible... The E-anxiety brought on one or two of these.
Finally, the board was slung together enough to bung into the case.
After having a complete ball ache getting the motherboard to line up with the case, it's in...
My issue now, is that I have two case fans, and zero clue where to plug the buggers in?!?
UPDATE: The card went back to Gigabyte, and was returned ‘no fault found’, was tested again by OcUK and same fault found, and was again returned to Gigabyte...
I only learnt this yesterday when I checked for any progress and I’ve already been offered a 2080 Super as a replacement.
I know I’m starting to sound quite the shill by now, but again I couldn’t be happier with the service from this place. Effectively been given an upgrade for the sake of some inconvenience.
Considering I could have simply been told to sod off for removing the sticker, can’t say fairer than that!
Hi Mate. How are you finding that motherboard? Can you hear the fan on the chipset at all when under load? I'm looking at getting the same board but have heard that the fans on the x570 boards can be a bit noisy so I'm not too sure about going x570 or x470
I think I've finally run out of stuff to do...
Just upgraded to the Razer Viper Ultimate because I wanted wireless.
I was intending to upgrade the monitor, but this one is a blinder. I'd be looking at something like the LG 34GK950G, which would be £800 for an extra 25Hz... Not worth it! I like the look of the Razer Raptor, but it's not availible over here, and I don't think I could go back now I have an ultrawide. If Razer drop an ultrawide then I'll go full shill and spend too much on one.
Maybe get a noble footrest for good measure?
I 'could' get a ThermalTake AIO and get some ThermalTake RGB RAM I guess. I should have got faster RAM in the first place, and the TT stuff can be controlled by Razer Synapse so it would all sync up, but I don't know if that's just throwing cash at it for the sake of it?
its curved isn't it. how do you find the curved monitor vs a flat one?Acer Predator X34, Refurbished but cosmetically perfect and works a treat![]()
I got a mid range (membrane I think not mechanical) Rzaer chroma cynaosa keyboard for Christmas and just love it - quality feelProbably my favourite part!!
Only got my old Roccat stuff to compare them too, but I love them. Razer stuff always feels quality to use, and their mice are certainly the best I've ever used. With the speakers, keyboard and mouse all synced up the whole setup looks brilliant.
Love the clever use of lighting on the speakers too.
Razer is pricey though...
