Just got a Phanteks Eclipse P400a case for new build,it arrived first so im having a look at it and usual connections,audio,usb front panel header etc, all fine and dandy.
I see the 3 pin fan cables from the fans also the rgb pins to go to mobo,but i thought there would be a wee hub for the fan cables to go to seeing as theres 3 of them,am i missing something here?
Or do have to use 3 seperate fan headers on the mobo plus the rgb one for the leds lights,there is a fan controller under the top of the case for 3 speed settings.
Anyone else have the case and using the supplied fans?
Been over 6 yrs since i built a pc so be kind!
TIA
TIA
