That's not correct.
Look at this diagram. The bottom and top lines are parallel and all angles are right angles. The bottom line is not 16 units though.
Haha. I was working on the assumption that there was an invisible line on the right that showed that the 5 and 4 length sections were aligned, but yeah being pedantic as possible you could say my comment was wrong.They've maintained the same distance in the Y axis. The other guy could have added that if we're being pedantic, which we are.
Ah, I made a deliberate *cough* mistake. Cant see how you can actually get to a figure. bloodiedathame seems nearest?
If it was my son I'd have him put something like "20*16 - 11x" where x is that missing length
265m2?
It looks like a square but what with monitor resolutions it might not be, I'd measure the missing shape and if it's a square just do 20x16-11x11.
Measure the indent with a ruler and see if it is a perfect square, it could be a common sense test.
I think you need to look at the problem again and apply common sense...
