Caporegime
- 18 Oct 2002
I'm not seeing an internal scaler? and for sharpen do you mean set to 0.80?
Sorry I thought the game had an internal scaler, and yes it's 0.80 (it's % on AMD)
edit -
I have been ignorant of the clean versions i must start using them asap and read that thread. Is it only on guru3d you find it and is there anything to note about it?
Anybody that plays world of warships on a NV card what driver are you using as I've got a really old one and wondered if any of the newer ones work well,thanks.
I have tried a couple of different NVidia Driver cleaners but I actually prefer NVCleanstall.
https://www.techpowerup.com/download/techpowerup-nvcleanstall/
Never had a problem with World of Warships and I`m always using the latest drivers.
Yes and yes.They are safe right? I had a question does it still give the option to only install the driver? Currently i do not install physx or audio faff etc.
Sweet! - That sounds like it’s SLI support is now sorted.SLI in RDR2 scales very well for me on 2x 2080 Ti's with vulkan and allows me to never drop below 60fps at 4K.
What cpu are you running? - I’m guessing you’ve got a bit more grunt than a 4790k.....
Signatures don't display on mobiles, I see it now I'm back home on my rig.Should have gone to specsavers!![]()
Signatures don't display on mobiles, I see it now I'm back home on my rig.![]()
Problem Event Name: LiveKernelEvent
Code: 144
Parameter 1: 3003
Parameter 2: ffff860bfebf76b0
Parameter 3: 40010000
Parameter 4: 0
System freezing...
Good Game Nvidia
Like this at idle constantly...
You have an OC applied?
I've had DDU cause no end of weird crap before, stopped using it and no longer suspect my GPU of being broken!I DDU nuked the driver, 2D Idle clocks are back to normal, hopefully that will stop the random freezing.
