ASROCK X570 TAICHI - THE RYZEN 3000 MOTHERBOARD GIBBO & 8 PACK RECOMMENDS
SoC @1.1v seems to be a must on ASROCK boards. Mine needs it on my Phantom gaming 4. And my RAM needs 1.4v at stock settings 3600 16 16 16 32
Well - I got the cold boot issue again last night. I had reverted back to 2.10 when I had issues with later versions before and has been fine since, until last night. Sat there with fans on loud for a bit, rebooted, same again. Got into bios and all options had been reset. Manually set everything back as before and it booted up fine. It's an odd one, don't know what it's started doing it on this bios, unless it's a board fault. :(
Most on auto with mem on XMP and custom fan profiles.
Just to check and not teaching you to suck eggs, but when you have save & exited BIOS with new settings - do you go back into the BIOS and save it as a profile?
Mine doesn't have it, it lists all the other fan controllers but nothing for SB?
I'm looking in the bit where you control the fan curve with the graph etc... Is it somewhere else?
H/W monitor >> Fan config.
Can you disable the software and give this a shot space monkey? My board is the Gaming X ( basically the same board)
Hi mate,
Right, I've disabled the software in windows, so its only the BIOS sorting the SB Fan speed.
It works as described, silent is low rpm, full is loud etc... though I've found with the windows software or the customise option in the BIOS that you can get the fan speed lower than the pre-set Silent option, and of course you can set a fan/temp curve :)
Hi mate,
Thanks a lot space monkey I'm not able to find the software on the website ( found some for a x370 ), yeah the BIOS option is still noisy on full load so good news with the software
So when you set the BIOS to silent, it still is loud?
When I made changes within the BIOS screen the fan speed automatically changed, without needing to exit and save.
Have you check the fan connector on the board, a lot of others have had the same issue and it was a wiring problem?
