Had a chance to try out the CRT that came with the 386 this evening. Still in its OG box with inserts. Also inside the box were 2 beige kettle leads to match although I opted to use my known safe ones instead...
It does work but with some problems, the brightness is stuck on max and in lower resolutions there are lines at an angle almost horizontal to the screen. Appears that this is caused by dead caps but I do not feel thats a job for me to be trying.
I really just wanted this for the case but I dont think I can break it up now. I wouldnt even be making use of the lcd or turbo with my intended pentium system. Once the cmos battery arrives I am tempted to try and flip it and put that £ into buying something more suitable!
