Caporegime
- 8 Jul 2003
- In a house
del
Installed my reference 5700xt this morning, left it standard and was quite loud. Upped the power voltage it was boosting constantly over 2000mhz but the junction temperature was hitting 110 briefly.
Timespy score of 9806
graphics score being 9543
Gtest 1 65.69fps
Gtest 2 52.27fps
ive done some tweaking and dropped the target to 1900mhz/1000mv with a 10% power limit and 38% fan speed.
I ran Timespy again and got a
combined score of 9371
Gtest 1 62.20fps
Gtest 2 49.90fps
The Fan currently tops out at 2000rpm briefly but mainly hovers around 1650rpm
GPU temp sits around 70c and the junction temp is between 79c-85c
im going to try and tweak a bit more but im genuinely impressed at how quiet you can get this card at the expense of 3fps.
Consider downvolting. 1900Mhz/960mv (970mv if you have crashes), 1780-1800Mhz ram. 0% PL. Leave the stock speeds on the fan
I'll give it a shot, assuming this should lower temps even more?
Oh yeah. While barely lose any performance.![]()
What temps should I expect?
Mine needs a good dusting atm
Do you run it in a dust factory!??? You know case dust filters are a thing right???![]()
65-70C core, ~85C hotspot at 2048rpm. Depending case. Mine needs a good dusting atm that is due tomorrow![]()
I was getting complete stuttering with mine, tried DDU and 2 different drivers to no avail.... returned the card and got a 1080 and all stuttering has goneI stick the 1060 in and it's all good so at a total loss as to what's not playing along.
Yup tried everything ,might box it back up and ask for a refund maybe keep 1060 untill new cards come out or buy a 2070s
I would run DDU in safe mode and uninstall all the drivers from both AMD and Nvidia. Then, before installing the latest drivers from AMD, download and install the latest AMD chipset drivers. Then install the AMD GPU drivers.
