Wow, Mercedes have something seriously trick going on with their steering rack that looks to affect the front track moving between corners and straights.
Watch as Lewis straightens his steering, it moves towards him and at the same time the two front wheels appear toe-in on the straights perhaps for better tyre life?
Goes back to toe-out as he begins to steer with the steering wheel going back in.
motorsportweek.com said:Article 10.2.3 of the FIA Formula 1 technical regulations which govern suspension and stipulates that “no adjustment may be made to any suspension system while the car is in motion.”
Article 10.2 adds: “With the steering wheel fixed, the position of each wheel centre and the orientation of its rotation axis must be completely and uniquely defined by a function of its principally vertical suspension travel, save only for the effects of reasonable compliance which does not intentionally provide further degrees of freedom.
“Any powered device which is capable of altering the configuration or affecting the performance of any part of any suspension system is forbidden.”
Do hydraulics count as powered? Anyway, I didn't see any change in the camber of the front wheels, so maybe it's adjusting something else, like the undertray?
It's the toe of the wheel that gets changed
I've just watched the second video a few times and I'm not seeing it. What I am seeing is that it is indeed the wheel and that the whole of the wheel is getting pushed in or out. The angle of the toe doesn't seem to be changing.
That's what I am seeing as well.
https://www.formula1.com/en/latest/...ew-steering-wheel.78KDOPX7xRy9YtaFZPCKC4.html
Very clever and a game changer. Just shows how long Mercedes have been working on this car. Mercedes will as ever not show their true pace in testing, but it’ll take other teams a while to implement this.
Very clever indeed, I wonder if they'll be allowed to keep it though.
