Caporegime
- 18 Oct 2002
Could be the cable. I had issues with the OEM one and swapped it out.
edit - No matter, saw my answer above.
Just power off the monitor via osd and power on again and the 160hz is back
What cable are you using please?Got it running absolutely fine with a really cheap oem cable (doesn't even have retention clips!) that seems to be a superstar in disguise!! Ran 4k/120hz fine and now this, what a great cable thanks for throwing it my way when I needed one @Azrael1 !
Hilarious what a trash cable LG supplies with this beast
Many thanks; Ordered the 3m one.I use this cable for both my X35 and 38gl950g and it works perfectly and it's not too thick or rigid
https://www.amazon.co.uk/LINKUP-Dis...inkup+displayport+cable&qid=1583405239&sr=8-4
Missed the gun with this, looking around, it's in very short supply here and as a result, the prices are jacked up considerably.
£1599 here and in plentiful supply it seems
https://www.overclockers.co.uk/lg-3...een-led-backlit-curved-monitor-mo-15g-lg.html
unless OcUK ships internationally which I don't think they do?
They do afaik, speak to them
So much for the price not immediately dropping like some people in this thread were claiming.£1599 here and in plentiful supply it seems
Asus PG279Q fyi.
