Lovely base core clock, pretty sure that's on the higher end of most samples.
Well, your out of the box core clock is higher than most of the samples i have seen, and equal with my sample.what does that mean ?
i got a special card ?![]()
I've got an i5 6600k well worth it , look at the price of Vegas and Rx 590..
Thinking of upgrading my 970 for The Radeon RX 5700 XT - is it a good bang for buck upgrade? Trying to get ready for Cyberpunk 2077 and will be paired with a 6600k (at stock). Ideally only wanted to spend around £250, but at £300 seems like a very good deal.
Odd. My nitro+se is 2100/1184mv with 1800 memory.
Ive been trying it at 2100/1075mv and it seems to be coping so far, but haven't had a chance to give it a proper long game test.
I bought the 5700xt as a stop gap for Big navi, it performs so well i may skip it and wait till it either comes down in price or until its refreshed.
Damn good cards man, damn good.
Mine was also 1800, depending on bios switch which you change on the gpu or use the software to change
Does the red devils have a switch too?
