Can oxygen sensors go bad, in other words if your regularly getting carbon build up that triggers a fault code is it the sensor at fault or something else like a leaking seal.
Cleaning it seems to be a temp fix etc.
Change it.
Depends which one it is and where they are on your particular car, the number 1 sensor on my old astra was easy as it was right in front of you when you popped the bonnet. Number 2 was in the exhaust so a bit more of a pain in the bum but still not particularly difficult to get to once up on stands.Is it simple enough to remove them and clean with carb cleaner?
#2 sensor plays no part in the actual engine management. It is for after cat monitoring only.
However a faulty one will trigger fault codes.
Doesn't it? My understanding is both sensors detect oxygen levels by measuring a voltage with exhaust gasses passing over them, the ecu uses the difference in voltage between the 2 sensors to determine how much oxygen has been burnt and manages the fuelling accordingly for maximum efficiency.
