Hi everyone, after a long time away, I need some help! Tried building a new rig and appreciate my last build was over 10 years ago but gave it a shot anyway. Needless to say, it has ended in failure hence me asking for some help. My components are below:
ASRock B450M Pro4-F mobo
Aerocool Cyclon 700w PSU
Ryzen 5 2600X
XFX Radeon RX 570
Adata XPG Gammix D10 8GB 3000 MHz RAMx2
Thermaltake Versa H17 case
Adata XPG SX8200 512GB SSD
Tried installing everything in order:
CPU lock opened, CPU in the right orientation, lock bar closed.
Heat skin screws taken off mobo and whatever the metal bars are as well. AMD stock heat sink inserted and screwed in place, fan attached to mobo
RAM installed in nearest 2 RAM slots and clicked in place
PSU screwed into case
Mobo installed in case with screws to risers to secure
Case cables like power butting, power LED and reset button plugged into mobo
SSD installed and screwed in to mobo
20 pin mobo power cable and 8 pin acPU cable slotted in securely
Graphics card installed and 8 pin power cable fitted
USB 3 and “normal” usb connectors plugged into mobo. Case fan plugged in as well
PSU switched on (makes a faint whirring noise)
Power button pressed - nothing happened! Made sure kettle lead plugged into working socket
Took everything apart and tried an outside the case build after removing case to mobo buttons and re checking manual to make sure I hadn’t plugged the in the wrong way.
I’ve now go PSU connected to mobo by 20 and 8 pin connector, CPU and heatsink connected, heatsink fan to mobo, graphics card installed, RAMx2 in, case power cables to mobo. Still nothing
I presume I’ve done something really stupid, can one of you geniuses let me know what I’ve missed? Happy to answer any questions you may have. Apologies for my incompetence!
edit: is it my RAM which is incomparable at 3000MHz?
Ryzen 5 2600X
XFX Radeon RX 570
