Yes, the build needs a friendly pale person or a curlew in it to finish it off nicelyI was browsing away tonight and have found a little something for the build. Might take a while to get here but should be a nice little finishing touch![]()
Yes, the build needs a friendly pale person or a curlew in it to finish it off nicely![]()
Good thinking
Was going to mount couple ssds on my psu shroud
And make couple holes with a step drill
And shove some grommets on the holes
Too busy right now though
Finally got round to trying to organise the computer room so doesn't look like
A bombsite lol
It's looking fantastic vincenzo, watching intensely!Because you asked nicely @Illuminist
That's pretty direGot home today all excited as a new part turned up direct from corsair for the 275r the little top cover bit for when you don't want to look at the grills. Anyway I opened it.. what do you guys think? Something gone wrong at Corsair QC quality control? @Corsair Nick ?
Two missing magnets down the bottom there:
Two opposing corners like this:
On the wonk:
It can't possibly have meant to be like that... can it? Now I am in two minds, the colour is way off but I didn't intend to keep it white anyway as purple right? But the general QC for a product direct from the manufacturer I almost want to send it back. There are enough magnets of the correct size to use one in each corner but should I have to take a product apart and put it back together in a way that works?
That's pretty dire
#edit oh
This looks super cool so far! Will sanding down the edges fix the wonk?? Kind of looks like the cover is bent but might just the be angle! Looking forward to seeing more progress. Thank you!No on closer inspection it is properly rough and now i've lost a magnet and the other one just falls out, i mean I can glue them back in but a few of them wont stay in they just fall out.
Edit: You know what ive only gone and found it. Im just going to have to take em all out very lightly sand all the excess plastic off of the edges, give it a lick of paint and some glue... bet you it looks a million bucks.
Yeah I was thinking
Purple with something white stencilled on
Or vice versa
Hard to say if all purple will be a bit too much or not
Edit
If all purple does look too much can just stencil a white dragon or whatever
Over top of some of the purple
Looks great and the wonk has definitely gone! How are you planning on connecting the GPU to the Motherboard by the way? Looks like a long way to travel? I'm guessing it'll be ok. And are you planning on doing anything on the front of the case? Like pint the corsair logo purple at the bottom or is it too fiddly?
