The point is support is non existent.
Go to the site for drivers? It's community support. Non existent.
Reddit? What is reddit?
Jump through a pile of hoops, guy says use DDU and go back to 19.
I really would like some help.
No, that sounds spot on.Settled on 2000mhz / 1050mv for now, gives me an average junction of 74 and GPU core of 51c. Actual frequency is still between 1950 - 1970 in game. Is it a bug ?
I ended up having to roll back again after installing 20.2.2, I'm currently using 20.1.4.
My problems related to playing STALKER Call of Pripyat with a mod on Steam, It's worth noting that I moved the mod to my GOG version of the game & the crashing has stopped so I may retry 20.2.2 later today as I might of been pointing fingers at the wrong people.
Edit: It is the driver as I get this info
FATAL ERROR
[error]Expression : Hardware device removed.
[error]Function : CRender::texture_load
[error]File : D:\prog_repository\sources\trunk\Layers\xrRenderDX10\dx10Texture.cpp
[error]Line : 493
[error]Description : D3DX11CreateTextureFromMemory ( HW.pDevice,S->pointer(),S->length(), &LoadInfo, 0, &pTexture2D, 0 )
[error]Arguments : e:\gog\s.t.a.l.k.e.r. call of pripyat\gamedata\textures\ui\ui_console.dds
That's what I've got now after speaking to ocuk tech I decided to go to Nvidia just reinstalled Windows now
Displayport mate its a shame it had to go back really and if I'd lived closer to ocuk I'd have tried the sapphire nitro but didn't want to take the risk again and have to take it backWondering, issues with the card/AMD ... Were you connected via HDMI or Displayport ?
Displayport mate
i usehow do you look at the JT temps ? rather than Core ?
Performance > Tuning is your friend.thanks
waattman has disappeared on the new drivers![]()
Various options to adjust the overlay can be found under the wheel cog > general section.thanks Matt, how do you adjust what you can have on the overlay? its saying an awful lot all over my screen !![]()
