20% off at Foodhub, code = OVERLOAD20
£10 min spend, dont know when it expires,
15% off at Just Eat, code = VALENTINES15
no min spend, expires sat 15th (tomorrow) at midnight
(codes found at hotukdeals)
20% off at Foodhub, code = OVERLOAD20EXPIRED
Any FoodHub corona codes about?
Looks like having those extra FoodHub accounts has started paying off. They have been emailing me various discount codes over the last couple of days.
Here is one for 20% off: 6025BKHOPT that I won't be using but I think it's for a single use so first come first served. Enjoy!
*No minimum order value. Coupon expires on 5th April, one-time use only. Maximum redemption value: £5.
i got some of those emailed to me, the first one was for 10% off and it turns out that was a mistake from Foodhub as it was ment to be for 20% off,
so i ended up receiving 2 emails, but the code was the same in each of them,
there is also another code CNTFREE15 for 15% off
some others have received £3 off a £9+ spend via email
i know it's legal for takeaways to be open for delivery at the moment,
not so sure if Foodhub should be encouraging the use of them with these codes though, they may end up getting some backlash in the media for it
Here's 3 more codes for £3 off £9 spend at FoodHub first come first served.
3103GPGFLA
3103DSH3Y4
3103DSFMUO
I've gone off takeaways until the 2 metre rule is over.
All expired, but thanks for posting
How did you get so many codes?
