Which 5700XT did you get? I was going to buy the Gigabyte Aorus one but they went in up price the following day so settled for a 2070 Super as they went on sale, should last me a good while though! How are you finding the 5700XT?
Looking forward to Cyberpunk 2077 though!
I went with Powercolo
ur Red Dragon 5700 XT which has 2 fans, as I'm currently limited for space in my case until I upgrade to a SFX PSU. I've had this card installed since about 5pm! DDU/uninstall nVidia drivers/install AMD drivers, all ok so far, my Freesync monitor was detected and enabled by default, great. This card has a BIOS switch; OC or silent, I prefer silence, went with that. So far its doesn't look like the zero fan mode is working, but they go to so low that I really can't tell anyway. There is some coil whine, not loud but there, I think I can just about accept it while casual gaming/without headphones and not a problem with headphones. I don't seem to be able to software control the fan speed over BIOS, but that maybe my Argus Monitor fan control software needs more updates. I thought I could hear coil whine just now at idle but it turned out to be my LED light bulb behind me
It's louder than my 1070 but it would be because it uses more watts. It's fine so far though, pretty good for the money.
This should have gone in 5700 XT thread really whoops.
