2 Apr 2020 at 02:43 #41 Joxeon Joxeon Soldato Joined 15 Oct 2019 Posts 13,442 Location Uk you can go up to 1.45+V on the dram so 1.40 is well inside voltage safety.
2 Apr 2020 at 11:48 #42 Kevin Matthews Kevin Matthews Associate OP Joined 19 Jan 2019 Posts 511 Location Co. Down, N.Ireland Joxeon said: you can go up to 1.45+V on the dram so 1.40 is well inside voltage safety. Click to expand... It's 1.44 in bios already, don't know why ryzen master shows differently. And also anything after 1.45 bios it starts highlighting red. I've a B450 pro carbon MB. Ryzen 5 3600 with stock cooler. Last edited: 2 Apr 2020
2 Apr 2020 at 12:05 #43 Joxeon Joxeon Soldato Joined 15 Oct 2019 Posts 13,442 Location Uk What's it say it is in hwinfo?
2 Apr 2020 at 12:14 #44 Kevin Matthews Kevin Matthews Associate OP Joined 19 Jan 2019 Posts 511 Location Co. Down, N.Ireland Joxeon said: What's it say it is in hwinfo? Click to expand... If its the Dimm voltage it's 1.408
2 Apr 2020 at 12:17 #45 Kevin Matthews Kevin Matthews Associate OP Joined 19 Jan 2019 Posts 511 Location Co. Down, N.Ireland Actually for 3600mhz in bios I've set at 1.4 but beside it grey says 1.416 and in Ryzen Master it shows its 1.408. So you reckon I should push to 3800 maybe timings are making it unstable. Safe preset over fast preset?
4 Apr 2020 at 02:14 #46 Kevin Matthews Kevin Matthews Associate OP Joined 19 Jan 2019 Posts 511 Location Co. Down, N.Ireland Hi @Joxeon You think these be okay most stable settings yet; best free image hosting also have dram at 1.46v
