Hi all, Beena while since I have been so sorry if this is in the incorrect section.
Basically my system was
Ryzen 5 2600,
B450m ds3h
Corsair Vengeance 16gb
EVGA 750w
M.2 Evo 970 250gb for OS
2tb HHD for games etc
All worked fine.
Decided to upgrade to the Ryzen 7 3700x. Updated BIOS. Booted up all ok.
Went on to YouTube and video plays but get micro stutters.
It annoyed me so much I thought f it start from scratch. Fresh Win 10 1909 build install. Did all the updates restarted check YouTube no issues. Started installing everything and checking after each install seemed to be working.
Restarted loaded up GTA amazing butter smooth then bang micro stutter. Checked YouTube video you can see the stutter Started all again. New install blah blah. Back again.
After reading online some say Ryzen 7 likes higher RAM MHz and seeing as mine was 3000 I brought some G.Skill trident rgb 3600Mhz 16gb. Chucked it in enabled the XMP 2.0 but still the same issue.
I reverted back to a restore point after install and updates and currently sitting with no stutters. Done a Memtest but no errors found. Same for the SFC /scannow.
Video to demonstrate :
Anyone got any ideas or had same experience?
TIA
Ryzen 5 2600,
B450m ds3h
EVGA 750w
All worked fine.
TIA
