Man of Honour
- 8 Nov 2007
- Outer Space
How'd you get on?argh ok ,thanks for the info will give it a go
Does it still work as intended? My ASRock Taichi used to do that at times but it made zero difference to the PC?Anyone have their debug code at 40 after boot.
If i go in to bios first then load windows, it'll go AA..
I found the setting in bios but haven’t tried using it yet as the card is piped up in the water loop and a bit too short to get the cable inHow'd you get on?
Yes mine is the sameAnyone have their debug code at 40 after boot.
That was to do with fast boot in Windows. I don't like my machine going to sleep when I ask it to shutdown. So changed that and now I get AA on cold boot.Yes mine is the same
Ok thanks for the info , mine has fast boot enabledThat was to do with fast boot in Windows. I don't like my machine going to sleep when I ask it to shutdown. So changed that and now I get AA on cold boot.
Sorry its called fast startup in Windows.Ok thanks for the info , mine has fast boot enabled
Hi , looking at your video of the boot sequence is the bottom left LED coming on twice during boot , only mine only comes on the once then its in windows splash screen , I had a problem where it was going around in a loop and this was because I was trying to use a PCI-e 3.0 riser cable for the gfx card , I plugged the card straight into the pci-e slot and never had that problem againSorry its called fast startup in Windows.
What about my boot sequence video?
boot sequence as is https://youtu.be/aT9XfzsDAwY
I disabled ultra fast boot for the video , but in biosIts a strange. I've enabled fast startup and get to the login screen in 16-17 secs same as you. So I'm not sure its cycling, but the fans sure to stop and start seen my the fan leds. Not all fans cut off though.
Does anyone else have the following issue?
After the PC has fully booted and I'm in Windows my BIOS LED Code readout randomly changes? It's the first board I've ever had that continues to change after the PC is up and running?
Thanks, mine seems to prefer F8 (as it is currently showing) but it seems to fluctuate for some reason?Hi don't have that on mine , must say that sometimes after boot it sits at 40 and other times at A0 I think but never changes once in windows
Seems others on Reddit are having the same bios code of F8 as I am, plus one user mentioned they also are seeing the code change briefly?Hi don't have that on mine , must say that sometimes after boot it sits at 40 and other times at A0 I think but never changes once in windows
It may be linked to opening and running Ryzen Master, I'll have a look later today to see if that's the case?
Ah, so it's a thing then, thanks for checkingJust tried that on mine...it was sitting at AA ...clicked on Ryzen master icon and straight away it went to d3 briefly then to F8.
Not sure what it's normally at...last time I looked I am sure it was FF
