The Radeon RX 5700 XT Owners Thread.
18 Apr 2013
Liverpool
Red devil 5700xt :D
72xVyYs
Man of Honour
OP
21 May 2012
Dalek flagship
ROH Entry? :)
Red devil 5700xt :D
72xVyYs
Welcome and on TROH.:)
The Roll of Honour.
Date 14/04/2020, Make PowerColor Red Devil, Andygully, Link
Date 14/04/2020, Make AMD Reference, Phate, Link
Date 07/04/2020, Make Sapphire Nitro+, Figo, Link
Date 16/03/2020, Make Sapphire Nitro+ SE, InVitriol, Link
Date 01/03/2020, Make Sapphire Nitro+ SE, Brizzles, Link
Date 27/02/2020, Make PowerColor Red Devil, ShiWarrior, Link
Date 25/02/2020, Make AMD 50th AE, djay, Link
Date 11/02/2020, Make MSI MECH OC, Phil2008, Link
Date 18/12/2019, Make AMD Reference, Shilz, Link
Date 30/11/2019, Make MSI Gaming X, Toxile, Link
Date 25/11/2019, Make Sapphire Nitro+ SE, Kevin Matthews, Link
Date 02/10/2019, Make Sapphire Nitro+, EastCoastHandle, Link
Date 02/10/2019, Make PowerColor Red Dragon, Darren_uk, Link
Date 18/09/2019, Make Sapphire Nitro+, VaderDSL, Link
Date 17/09/2019, Make Sapphire Nitro+, TimAhKin, Link
Date 14/09/2019, Make AMD Reference, satchef1, Link
Date 09/09/2019, Make AMD Reference, Orange Nexus, Link
Date 07/09/2019, Make PowerColor Red Dragon, Aod, Link
Date 06/09/2019, Make PowerColor Red Devil, Ross Thomson, Link
Date 31/08/2019, Make PowerColor Red Devil, RedDeangelo, Link
Date 31/08/2019, Make PowerColor Red Devil, KentMan, Link
Date 31/08/2019, Make PowerColor Red Devil, Jimbo, Link
Date 30/08/2019, Make PowerColor Red Devil, iamcll, Link
Date 30/08/2019, Make PowerColor Red Devil, Satchfanuk, Link
Date 24/08/2019, Make Sapphire Pulse, lordhawkwind, Link
Date 19/08/2019, Make PowerColor Red Devil, Troezar, Link
Date 18/08/2019, Make Sapphire Pulse, howkey, Link
Date 17/08/2019, Make AMD Reference, Raelgun, Link
Date 17/08/2019, Make AMD 50th AE, Voodoo_what, Link
Date 14/08/2019, Make AMD Reference, DrSteve, Link
Date 10/08/2019, Make AMD Reference, Potatowithearsontheside, Link
Date 08/08/2019, Make AMD Reference, R3v4n, Link
Date 08/08/2019, Make AMD 50th AE, Besty, Link
Date 07/08/2019, Make AMD 50th AE, willb1967, Link
Date 31/07/2019, Make AMD Reference, ernorator, Link
Date 31/07/2019, Make AMD Reference, Kevin Matthews, Link
Date 30/07/2019, Make AMD Reference, FiremanSam, Link
Date 25/07/2019, Make AMD Reference, xxalxx, Link
Date 25/07/2019, Make AMD 50th AE, brightside229, Link
Date 25/07/2019, Make AMD 50th AE, Panos, Link
Date 20/07/2019, Make AMD Reference, InvaderGIR, Link
Date 20/07/2019, Make AMD Reference, Aod, Link
Date 19/07/2019, Make AMD 50th AE, BOFH, Link
Date 18/07/2019, Make AMD Reference, gavinh87, Link
Date 17/07/2019, Make AMD 50th AE, LtMatt, Link
Date 14/07/2019, Make AMD Reference, bake73, Link
Date 12/07/2019, Make AMD 50th AE, jrodga2k5, Link
Date 11/07/2019, Make AMD Reference, LtMatt, Link
Date 11/07/2019, Make AMD Reference, docsonic, Link
To get on the Roll of Honour all you have to do is post a pic with your user name on it of your Radeon RX 5700 XT.
10 Mar 2009
Newark
My 5700xt Under water. Managed to get the GPU block for £30 due to a pricing error on a competitor website, they are now back up at £99.98. I did mention it earlier so not sure if any one else got lucky?
The water in from cpu block to gpu took me 3 attempts to get right, but pleased with the result!
Not the best photo
23 Aug 2005
Having success with undervolting, days of gaming.. right up until I start doing things like alt+tab out of game for a bit, watch youtube or video a via potsplayer, 5 mins in I get a lockup followed by blank screen, after restarting event log says 'Display driver amdkmdap stopped responding and has successfully recovered'. Now, I actually think this is the driver rather the the undervolting, I guess if I test further with stock clock/volts I will find out.
1950 950 GPU 82C hotspot 99C VRAM 90C ~1840Mhz reported clock ** farcry crash in perks menu **
1950 950 GPU 81C hotspot 97C VRAM 92C power +0% ~1730-1850Mhz reported clock *mostly ok, 1 crash?*
1950 990 GPU 81C hotspot 97C VRAM 90C power +0% ~1840Mhz reported clock ** hard lockup/manual restart **
1950 1010 GPU 83C hotspot 100C VRAM 90C power +0% ~1790-1840Mhz reported clock gaming fine ** hard lock with far cry running and playing video in windows **
1950 1050 jumping there testing
Should the middle voltage be in the middle? coz it auto isn't.
Freq: 800 1375 1950
Volt: 750 800 1050 do I need to get my calc out? :)
26 Aug 2010
Freq: 800 1375 1950
Lazy mode on... I had this page bookmarked:)
https://old.reddit.com/r/Amd/comments/f84ph1/compilation_of_possible_navi_driver_fixes/
If you think your undervolt might be unstable try running OCCT GPU test with shader complexity at 8. I've found it spews out errors pretty quickly if it's not stable. I usually run it for 200 secs.
Context - I've been having trouble with my undervolts & the new drivers. I've concluded after a bit of testing that, for whatever reason it need's more voltage to be stable:p
My current undervolt is 2000/1055 & 25% on the power slider. Pretty sure I was stable at 1020mv on the old drivers. I should really do some proper testing:D
22 Apr 2008
Bryn Celyn Wales
I'd 2nd that with OCCT GPU test, it's been my stable with Prime95 for CPU and GPU stability for years, if anything is wrong with CPU Prime95 finds it even after an hour or two... and OCCT GPU test just stresses the hell out the system.
23 Aug 2005
Ok thanks will test some more tomorrow. Actually crash free 5 hours there in Far Cry 5 :) I need a stress and idle test seems to be when it has been crashing. My temps are warm side due to me wanting less noise btw. The powerslider seems to be black magic? some people say 0% some 50% and others 25% !
22 Apr 2008
Bryn Celyn Wales
I'm running a bog standard Powercolour 5700XT at 2074 (runs around 2005mhz) GPU and 1900 memory at 1200mv. Absolute full chat with 99% load for an hour shows GPU at 75C and Junction Hotspot at 105C now... and it runs solid. When I decrease the voltage I'm struggling to get the core to clock anything above 1930mhz ish... so, for me, it's designed to run warm anyway, I'm not bothered about noise as I game with gaming headphones anyway.
17 Mar 2009
I've had a couple of months with this card now and I think the card and performance are great but tbh I don't think the drivers are good enough which was a concern coming back from Nvidia. I get green screens, sound cutting out requiring me to unplug and plug the display port cable, random freezes. It's such a pita as the hardware is great but there is a lot of work to be done still.
22 Apr 2008
Bryn Celyn Wales
I'm running 20.3.1 and it's running sweet as a nut, what version of driver you on? I've not got any problems, running RE3, COD, BF5 and Monster Hunter World all maxed and sweet and sound. I'm actually astounded how solid this driver is for me although it always always crashes on first load, restarts then perfect from there on.
23 Aug 2005
OK undervolting doesn't do much until you relax the clock around 1900, then volts can come way down.
1950 1030 GPU 84C hotspot 100C VRAM 94C power +0% ~1790-1840Mhz 5 hours Far Cry 5 stable, OCCTGPUDX11 30 mins fine, Far Cry 5 benchmark 93fps
1900 950 GPU C hotspot C VRAM C OCCT 900secs passed
For reference: Stock clock/volts, temps with lower speed fans: GPU 84C Hot Spot 106C VRAM 92C Far Cry 5 benchmark 93fps
1900 920 GPU 78C HotSpot 93C VRAM 88C OCCT 900secs passed Far Cry 5 benchmark 94fps err :) clock is lower but frame rate went up by 1fps
Temps are max from 1+ hour of Far Cry 5, actual temps sit a couple of degrees lower.
23 Aug 2005
Far Cry 5 benchmark is inconsistent, 5fps+/- on each run, I don't have anything special running that might rob cpu/gpu, just running standard Windows Defender.
Superposition benchmark: clock @ 1900 run A: 52.85fps B: 53.15fps
Superposition benchmark: clock @ stock run A: 54.67fps B: 54.74fps
So it's 1-2 fps less in some things, decent trade-off.
23 Aug 2005
Shadow of the Tomb Raider benchmarks, both ran twice and same result both times
91fps at 1900 920
90fps at manual, gpu tuning off, vram tuning off, power set to +0%
89fps at tuning control set to automatic (stock)
:eek:
No crashes since setting to 1900 920 so far either.
22 Apr 2008
Bryn Celyn Wales
Assuming you're running at 1080P Extreme and that's maximum fps? For reference mine is:
Superposition benchmark: clock @ 2005/1900: Min:31.49fps, Avg:39.18fps and Max:46.38fps
