- 10 Sep 2003
- Midlands
US Air force KC-135R over Cambridge at the moment. Odd movement.
Right next to each other - I'm getting positions.
When you go to Essex Radar, if you click on Menu / Receiver, you'll see a list of where they all are. I don't mind duplication because some receivers may well pick up stuff that others don't, even if they're in the same area. For example, one of the recently added receivers has given me ground coverage at Manchester Airport which is absolutely fantastic, even though I already had coverage in the air over that area.@Feek, can you give a breakdown of the areas that are currently feeding into your Essex Radar site, as I'm thinking of throwing up a FA server after the current troubles, and want to know if a recevier in my area is already feeding you ? I'm in Wiltshire btw.
When I first looked, I didn't realise there were two there either as they were so close, I had to zoom in to spot them.Didn't realise there were two of them, thought it sounded loud.
It's on essex radar nowIs there? I can't see it on my tracker.
Looking at the Pi 4's which memory option is needed 2Gb or 4Gb, does the extra 2Gb on the 4Gb model make it perform any better with a FA stick ?
ok, last question for now. Where is good to buy all the FA specific stuff, like a decent antenna, and band pass filters ??
