GameMax F15M Gaming Case (Budget Cooler Master H500M)
TNA
TNA
Caporegime
13 Mar 2008
London
GameMax Mid Tower Gaming Case with Tempered Glass Side, Mesh Front | GMX-F15M
The all new GameMax F15 Mid-Tower is a chassis designed to suit all builds. The F15 has interchangeable front panels, you have the opportunity to purchase the F15 either with a tempered glass front panel or with a full mesh front panel. (Each sold separately).
The F15 comes with exceptional cooling, included is 2 x 200mm ARGB fans at the front and 1 x 120mm ARGB fan at the back, with a further two fans been able to be fitted at the top of the chassis and on the PSU shroud.
You can connect all your fans to the pre-installed ARGB hub allowing for stunning lighting effects and an easily sync any further fans you choose to mount. You can also sync all fans to a compatible motherboard using the included 3 Pin AURA and VDG connectors. Please note the hub can connect only six fans.
The left side panel is made of 4mm tempered glass allowing the user to show off their internal components and show off the light coming from the 3 ARGB fans.
The I\O panel located on the top gives you easy access to the 1 x USB3.0, 2 x USB2.0 and HD Audio (Headphone and Microphone), allowing for connection to a variety of different devices. The chassis supports GPUs with a max. length of 365mm and CPU coolers with a max. height of 165mm.
In line with the GameMax ethos this case offers style, performance and the ultimate experience.
Compatible with the Following Fans
The GameMax F15 is compatible with the following fans:
  • GameMax Mirage Dual-Ring Rainbow RGB 120mm Fan
  • GameMax Mirage White Fins Dual-Ring Rainbow RGB 120mm Fan
  • GameMax Razor 120mm Rainbow ARGB Fan
  • GameMax Velocity 120mm Rainbow ARGB Fan
  • GameMax ARGB 3 In 1 Kit
Compatible with the Following Hubs
The GameMax F15 is compatible with the following hubs:
  • Spectrum ARGB Hub
  • GameMax ARGB Fan Hub
Main Features
  • F15 Range - The F15 is available in either a tempered glass or mesh option. The tempered glass front panel enables the perfect blend between aesthetics and performance, or the F15 is available with a full mesh front panel enabling direct airflow.
  • Motherboard Sync - You can now take your colour customisation to new levels with the included ARGB motherboard connector, simply connect the 3 Pin to a compatible motherboard and you can use the mobo software to sync your fans the way you like.
  • ARGB Hub - The F15 comes with a hub included and can connect to 6, 3 Pin or 4 Pin fans, from the hub you can control the colour mode, fan speed and LED speed. The hub comes with an AURA and VDG connection. Compatible with ASUS, MSI and Gigabyte RGB Fusion.
  • RF Remote Controller - As well as been able to control your fans from your chassis using the built in hub and 3 Pin AURA connector, you can control your fan speed, LED speed or colour mode without any fuss using the RF (radio frequency) remote control. Using the remote control gives you easy access to 5 pre-programmed colour modes and several different colour modes.
  • Water-Cooling Support - The front supports a 360mm radiator, a 240mm radiator can be mounted at the top and on the PSU shroud and a 120mm at the back of the case.
  • Tempered Glass - A full left side tempered glass panel has been included allowing the user to show off their build and the glow from the ARGB fans.
  • Vertical & Horizontal GPU - The F15 offers vertical or horizontal graphics card mounting, allowing you to be flexible and adjust your build to suit your needs.
Anyone else got one of these? Currently can be had for around £60 online.
They look pretty much like a Cooler Master H500M with some extras included.
Tempted to grab one, but at the same time never heard of GameMax and it is not like I need it as what I have more than does the job, just a case of trying something new without being wasteful.
  • Spectrum ARGB Hub
Main Features
I had a GameMax case a while back, and tbh for the money they are decent quality imo.
Made the order. Let’s see how it compares to my current case.
What do you think of the case? I recall you was after something like this @orbitalwalsh
Here is a review of it:
Includes vertical GPU mount, 2 x 200mm + 1x 120mm RGB fans with remote controller, removable filters plus very good airflow, looks amazing value for £65. Plenty of room for other fans as well.
Seems pretty much silent on lowest fan setting too, didn't mention what it's made of but even if it's plastic it's great value.
If you guys act fast it can be had for a tad under £60 at the moment online with free delivery :)
I would but I only just upgraded to a Corsair 450D with added expensive ML fans end of last year, definitely happy with what I got as I wanted 5.25 bay as well, but that Gamemax is just insanely good value for money by comparison.
RGB 20mm fans aren't cheap at all, they actually look pretty decent as well and quiet with that controller. Has to be one of the best value for money cases ever.
Well, i have the H500M and this Gamemax case have 3 better things:
- The A-RGB + Fan hub
- The tempered glass side panel removal
- The PSU shroud is 10x better
Mad ain’t it? Goes to show how much profit CoolerMaster are making if GameMax can make this case at this price point.
Yep. I've bought mine on a Black Friday deal, here in Portugal, for about €140 with shipping.
It's nice but it's not a €200 case!
The 2 piece psu shroud...omg. :mad:
You should also take a look on the Antec NX800.
First time I have seen the Antec NX800. It looks good also. But still more money and you do not get a remote control which I like. Nice easy way of controlling fan speed and colours :)
First time I have heard of GameMax and they look like they offer excellent value for money relative to the others.
I would Recommend the GameMax F15m for the £60 price, Compact for a mid-tower & so many features, even get 2 x front 200mm ARGB fans & Rear with fan box,
Kicks ... the £200 cases with 2 x ARGB fans.
Hope Gamemax do a White version of the F15
The 200mm ARGB fans each run max 800rpm & do around 104cfm :)
Due to get mine in 8 days time (went with free delivery) as no rush whatsoever :)
Been thinking of purchase it, but gamble on an all-white version & just hope the price doesn't skyrocket, I can see it will.
the mind is still telling me to buy it :D
