Permabanned
- 9 Aug 2008
I'm going to wait for the 2004 H1 RTP I think. Don't want to join the program.
Hi guys,
A quick one; Is it possible to change keys without having to re-installed Windows 10? Scenario; I have a machine that I need to work on from home this week but it is only x32 and 2/3 apps I need to be using require x64...
I have a brand new x64 retail copy/key of Windows 10 from launch that I could use but I 'm loathed to start having to re-install anything
Thoughts?
Yep, just found some more info from MS on it... that's annoying, guess I'll be on the work laptop for a lil bit longer thenYou can change keys easily, but you will have to reinstall to go from 32 to 64 bit.
Not just an issue on 10, as it was the same on 7, but why can't i copy/paste error codes into a search engine. Instead I have to type in a series of "is that a O or an 0?".
Addresses an issue that causes Windows Update to stop responding when you check for updates.
Only just got this popping up today. Installing now..
I installed the Cumulative Update last night not long after I posted. Everything seems normal - so far.Good luck!![]()
I installed the Cumulative Update last night not long after I posted. Everything seems normal - so far.![]()
Installed no issues... 18363.815
Be a while before i give 20H1 a try, be reading feedback first, see how many machines have been hosed by it
I'll be quadruple cloning first too![]()
Same .815![]()
20H1 is gona be released on the 28th May.
