- 24 Sep 2015
This page also has locations that are getting FTTP.
Yet BTW are rolling out FTTP to the poles everywhere currentlyAs if we need more broadband options
No mention at all of either of the local exchanges here. Down with that sort of thing.This list isn't exhaustive but shows most of Openreach's planned work:
https://www.openreach.com/content/dam/openreach/openreach-dam-files/images/transparency/April 2020 Transparency Data Capture.pdf
I wish BT would get their top fibre packages on offer here to give a little competition! Max they offer is 50Mbps with zero idea when FTTP will be launched.
Probably because of the share price dropping I think. I was thinking to wait to order it myself but could be waiting a while!
Same situation here, one of the first places to have FTTP activated and now I'm ready to order it as my contact is up end of May I can't.
Probably going to switch to Sky and hope they offer FTTP at some point later this year so I can upgrade.
Sky would need a Openreach engineer to attend your property to install FTTP,
Is this the same as the early days of ADSL?
Hope they're willing to run it where you ask.Completely different - an engineer is needed to terminate the actual fibre afaik
Would they terminate in a loft space?
If you want the fibre putting somewhere other than an external wall then you'd be well advised to run in some flexible conduit and putting in a string so the fibre cable can be pulled through it. It also makes it really simple to replace the fibre in the future.
https://cpc.farnell.com/pro-elec/acp20blk/contractor-pack-10m-m20-glands/dp/CB19783
If you're on a ducted underground feed currently then the fibre will pop up in the same duct - they won't dig a new trench to you, so bear that in mind.
If your loft is fully boarded then I would assume they'd be OK with this, otherwise it's too much of a liability.
I assume when I get my FTTP installed I'm hoping to get the 900mb package from BT, my powerlines that I currently use wouldn't quite be up to the task? And best to run Ethernet cable to my PC from the router?
