Does it make any difference which way a GPU is Mounted ?
Caporegime
27 Nov 2005
Guernsey
I own a Silverstone FT02 case where the GPU is mounted in a straight Upright position..
Could this effect how well the Heat pipes in the GPU cooler work ? :confused:
as this means most the Heat pipes go downwards (But Heat rises )
Best example I can think of is it be a bit like mounting a CPU tower cooler upside down :D
You should see a considerable noise benefit as heat rises up and out, particularly if you use a blower cooler. The fans won't run so fast. But since you mention heatpipes, I'm guessing you have the other sort, and even then you benefit because the whole assembly is blasted by air from the GPU fans and the hot air that's blown away is blown up and out by the case fans.
WOW I just put my PC case on it side to test this and the GPU temp gone from
About 76c with 100% fan speed
to
About 63c with 51% fan speed plus there was an increase in the gpu mhz
Still one of the best case designs for component temps !
Mounting cards vertically in a standard design case is worse for temps
Looks like it could be one the worst case designs now as GPU's coolers where never really designed to be mounted upwards in 99% of PC cases
It was great for GPU's with air blow coolers but there not many of them around these days on the top end cards
For the record - Heat does not rise. Hot air rises.
If you don't believe me, hold a spoon upright by the bottom end and put a blowtorch flame on the top.... then wait a few moments.
This is why your air-cooled heatsinks still work so well, despite being mounted sideways. ;)
Nice case, though!
It's more the airflow of their cases, specially one with dual 180mm that sit underneath the GPU, and exhaust heat shoots up the top due to negative pressure. Half the time though people have their cases set up with naf airflow and filters . Dynamic is a stunning case but filters are aweful. £80 order to South Africa and you drop 10c all around with better filters :D
The actual manual of the ft02 recommends against using gpu's with axial fan coolers and instead they prefer a cooler that dumps heat out the back. Because of the way the case is designed with it basically being a bottom to top wind tunnel the axial coolers mess with the airflow by throwing hot air all over the place. My 7990 was like an inferno in that case, though to be fair it ran hot regardless of case. As for heatpipes, doesn't matter what way they're oriented.
Take a look at these temps and the fan speeds,
These are both with the exact same settings and the PC case side panel removed
The only difference is one is with the case in it normal upright position and the other one is with the case on it side
Must be able to dump the air better with the case on its side.
No it is to do with the heatsinks not designed to be mounted vertical as when i put my hand over the heat sink there only hot air coming out the upper part of it and cold air coming out the lower part...
Looks like i need to buy a new PC case :( As i can't see any other way of getting around this problem
It's probably down to how that case works more than anything, it's pulling in cool air and firing it up, that heatsink is throwing the air around and probably recycling the heat. Would make sense the fan nearest the intake is cooler than the one furthest away. Same issue with my 7990 in that case and that heat sink made use of a vapor chamber but got the same results.
Guess where the GPU is.
The only way orientation will really matter is by changing it's supply of air. Air in the case isn't all at the same temperature.
It's probably down to how that case works more than anything, it's pulling in cool air and firing it up, that heatsink is throwing the air around and probably recycling the heat. Would make sense the fan nearest the intake is cooler than the one furthest away. .
The side panel removed so it not a build up of heat in the case ;)
But that don't explain why the GPU temp drops by about 30c just by leaning the case over
If the temperature changes just by leaning the case over then I'd be amazed. mavity should have no effect. Air (inside a confined system) isn't really affected by mavity, currents created by fans dominate.
If the temperature changes just by leaning the case over then I'd be amazed. mavity should have no effect. Air isn't really affected by mavity, currents created by fans dominate.
Look at my post number 10
Temps went from 79c with 78% fan speed to 66c with 55% fan speed
