- 15 Oct 2003
- Chengdu
That’s a lot of fans!
Looks great. Love those cables; really suits the "rainbow puke" theme (not being sarcastic here; I think it works well in white cases).
I gave water cooling a go last week. Found it an incredibly stressful experience. One of the EK fittings I bought of OCUK leaked and spewed water all over my motherboard, breaking it. Got a replacement motherboard and ordered some extra fittings. Then the other EK fitting (fortunately the one I was using for the drain, which was outside of my case at the time) wouldn't grip the tube properly. So that's me put off EK for life; the rest of the fittings were Barrow, and worked fine. Finally got it all working, booted my PC up and... no video output.
I'd hit breaking point by then. So I disassembled the whole thing and went back to air cooling, praying I hadn't broken my 5700 XT. Want the punch line? The GPU was fine. The monitor was set to the wrong input. So chances are the loop was working
I might try again one day, with a more suitable case and better parts. But for now I think I might just focus on buying quieter air cooled or CLC parts...
How are the thermals in the UMX1? It's beautiful, but I don't see much potential for ventilationI'm in China so they are everywhere here.
Really not sure in UK.
Heres mine,
I am still wating for my fan extension cables but i nearly got the system the way i want it, I am still deciding to take the prism wraith fan top off the heatsink and place it inside the case for a light show but it might be abit much. the system is black and white with a littile red as the motherobard and gfx card have red leds and i thoguht i would put a dead pool in there, lol
shame about the orange leds on the gigabyte x570 master you can not change colour on the board.
3900x
32gb ram from team group
noctua HS
Noctua fans
H510i case.
2x Samsung SSD
1x NVMe corsair mp510 drive
veag 56 sapphire pulse.
first build since 10 years ago wheen i built my i5 750 lunnfiled 2.67ghz + Radeon HD 5770 1gb ram, which i still got. a littile upgrade i think. lol
heres a image of the system
Nice setup mate, one q though..do you have no intake fans on this setup?
thanks
front fans nope, I read a lot of reviews for the 510i case and the intakes do sod all, lol but to be honest my temps are fine
top fan is a 140mm and rear is a 120mm and the cpu fan is 140mm i think
chipset 50c to 55c no fan running as it needs to get to 60c for that to kick in and has not yet.
cpu idle 40c to 50c depends on whats happening on the desktop and at full stress load its about 80c
systems about 38c i think not to sure on that
i was thinking of putting some dummy fans in as it looks a bit bare there but i will have a think.
Decided to try Ryzen and go Mini DTX
