Thanks to both LtMatt and Brizzles
Been playing Far Cry New dawn - max temp 73c -No problem I trust ?
I am just a little concerned that the board does seem to overdo it ref voltage but I do not know how to settle things downor if it is possible!!
Am coming from a 5820k system which was much easier to control (then again it only had 6 cores!) and I appreciate that Ryzen is a little different.
Will try with Performance enhancer - level 3 and the power profile you refer to - am not too bothered about all core performance as principally the system is used for gaming and I am not looking for the fastest since ..... but anything which would reduce volts/temps would be appreciated.
Throttling occurs around 90 degrees+, so your temps are fine.
The voltage looks high when you first start using this chip, it did for me also and i started to panic at first.
Buy once you realise that it is normal behaviour it does bother me now, just an understanding curve.
If you load the cpu you will see that the constant load voltage will drop to a steady ~ 1.20v - 1.25v
I came from an i5 4670K so Ryzen was totally diffirent to anything i was used to.
