AIO orientation question
12 Feb 2013
Cumbria
I've been told that if you front mount an AIO that the radiator should be positioned so the hoses/tubes are coming from the bottom and not the top as it can cause air bubbles and cause coolant to disapate quicker is that true?
also if positioning an AIO at the top of the case should the AIO be above the cpu or does it not matter? for example if the top of my cases can take a 420mm AIO but I put in a 280mm AIO and have it near the exhaust fan?
21 Dec 2019
Planet Thanet
Makes sense
Though never had an AIO in front of the case
Though the length of tubing may be a factor if can do it
For top mounted shouldn't matter
I have done nearer to rear exhaust like
You mentioned
And nearer to front of the case too
OP
12 Feb 2013
Cumbria
Makes sense
You mentioned
thanks for the reply. If I do mount the cooler at the front Ill put it with the tubes coming from the bottom as there will be enough length. I'm getting the artic freezer 2 btw
15 Aug 2005
Glasgow
I've got the hoses at the top on my Corsair H115i, pretty sure that was the recommended mounting at the time. Seems there are arguments in favour of either arrangement.
OP
12 Feb 2013
Cumbria
Luckily most cases have slots rather than just holes now
So being able to slide it further back/forwards is really useful
Yeah mine does (fractal r6 tempered glass, open layout)
It's probably negligible in the amount of coolant loss. Most people have hose at top
21 Dec 2019
Planet Thanet
Not totally surprised
They're selling more stuff than at xmas
With all the work from home people
And people self isolating buying stuff
To cheer them selves up
Just had to buy a printer and they're in severe short supply same as webcams
