- 16 Aug 2009
It's pretty obvious your cpu does not like 3600mhz.... Run 3533mhz no issues..... Done... Most of the time these issues are absolutely nothing to do with the board just the cpu....
Who says 1.4v is the max safe?? Dear me 1.5v is totally fine.... No issue...
8d is RAM issue can't pass training.... This can be timings, frequency or Cpu limitation with the settings your trying to train....
Well my assumption was because thats what it says on the box "1.2V ~ 1.4V ultra low working voltage"
I'm not trying to train anything its literally just the plain ol' XMP settings in the RAM. Everything is at default/stock/out of the box never even run the Dram calculator can't be bothered messing about with all with that stuff! I've never had any issue like this with any ram sticks in the past. I dunno about anyone else but if I paid for 3600mhz I'd expect it to at least run at, y'know, 3600mhz!
I'm not trying to win any world records for overclocking or infact anything other than buying a board cpu and ram and somehow expecting them to "just work" out of the box because honestly I have better things to do, or is that an unreasonable assumption? Because otherwise clearly I'm missing something here.
i have had the same problems with all BIOSes
Same here.
Boy this board gets hot! I know the radeon Vii isn't doing me any favours thanks to essentially blocking the chipset cooler fan grill, and venting into the case but chipset is hitting very high 70's and fan ramping up above 5000rpm. The motherboard cover plate get's pretty hot to the touch as well. I'm using a corsair air 540 case with twin 140mm fans on the front, one of the rear and one up top. Plenty of air flow. I've tried running with side panel off and laying on it's side which helps a little, but not as much as expected.
