Good timing, literally just ordered the Mi A3 128GB. Should do nicely as her birthday present, thanks for the adviceSo what did you go for?
I now must resist ordering LG 27GL850-B for myself....
It is a neat little phone. Its the phone I brought to try out android as I wanted to leave ios. Got a p30 now and enjoying the whole experienceGood timing, literally just ordered the Mi A3 128GB. Should do nicely as her birthday present, thanks for the advice.
Regular p30 or the pro one?It is a neat little phone. Its the phone I brought to try out android as I wanted to leave ios. Got a p30 now and enjoying the whole experience
Just the regular p30 as I brought the phone outright. Couldn't afford the pro unfortunatelyRegular p30 or the pro one?
So it seems Xiaomi bake some seriously questionable behaviour into their software and are collecting and uploading to their servers an astonishing amount of personally identifiable information. I’m far from a tin foil hat wearer but some of the info I‘ve been reading (starting with the below) its clear they are collecting far far too much stuff for reasons who knows what...
https://www.forbes.com/sites/thomas...oples-private-web-and-phone-use/#277727881b2a
So how many of you guys actually have one of the phones mentioned in this thread rather than the mainstream brands?
The realme 6 seems to tick all the boxes. Also the mi9t (pro would be better but at additional cost)
Phones are annoying
if you dont want to be tracked then use a dumb phone of old. (think 3310) whether its xiaomi, google, apple, amazon or whoever we're being tracked and our data is being harvested.
you can help yourself a little by using a VPN but aside from that im not really sure there is much you can do these days. ive privacy is a real concern then the internet is not for you.
Suddenly my less than a year old Mi A2 won't quick charge and is charging very slowly. Apparently it might be due to the recent Android 10 updates. Mobile has only charged from ~44% to 54% in just over 5 hours, concerning.
I had exactly the same thing with mine, it turned out to be the cable and charger I was using. Swapped out the cable and charger and all went back to normal, been fine for 2-3 months since.
I've got a Xiaomi Mi 10 Pro coming from giztop for £600.
It will have the global Xiaomi rom flashed.
I can only see the non-pro at that price - do you have a discount coupon?
Nice - thanks !
Anyone replaced a PocophoneF1 recently, missus has been moaning about hers even after a full reset, but not sure if/what could be available for a reasonable similar price (£265 or so from memory).
