Annoying Windows Sounds
27 Feb 2004
Kent
All the time windows (10) seems to give me sound alerts - but from where. They seem to have no meaning? Nothing changes except dee-dee-dah-dum sounds!
How do I turn this annoyance off please?
Mel
Could be notifications settings. type 'notifications' into the start search bar, and open up the settings from there.
You can sort the notifications by the most recent in that screen too, so it may show you whats been binging the sounds.
That sounds like a driver or device is disconnecting and then reconnecting. Possibly a USB device is sleeping and waking or a bit dodgy.
You could have cracked it there! My ASUS monitor has a USB hub and I was using this connected to my PC to run my graphics tablet and a Logitech mouse/keyboard "dongle". Disconnecting this hub has stopped these "extraneous / annoying" sounds!
Good thinking batman! Thanks, Mel
You can keep using it if you want, you just have to go into device manager settings and disable the hub's option to go to sleep.
Try turning the option about power mangament in the USB hub I thought was relevant and no effect. There are are 9 other "USB root hub" entries under "Universal Serial Bus Controllers" - how do I choose the right one!
Mel
Mel
If they are not easy to ID, just turn them off one by one till you find the one that keeps disconnecting and reconnecting when it tries to sleep.
By unplugging with Device Manager open, the offending device is called a "USB Composite Device" - and has no tab about sleep or power management! So stuck.
Ahem - probably yes - the Logitec dongle! It's easier just to turn the "System" volume down rather than waste both of out times! Thanks, Mel
That device is probably just going to sleep, and windows is seeing it disappear and then come back, hence the noise. Untick the power saving box in that device's properties, and it should stop happening. I had to do the same thing with a Microsoft keyboard that doesn't play nice with Windows since one of the updates.
